1999 Chevy Venture passkey problems
1999 CHEVROLET VENTURE
STEPHANIEFORD
1999 Chevy Venture
my mom used a copy of her key in her ignition and and it wouldn't turn. After that the Pass Key light came on and her original key wouldn't turn either. It is stuck in her driveway and a mechanic came out to look at it and couldn't fix it. Neither her or I can afford to take it to a mechanic again. What can I do to try to fix it?
Apr 17, 2008 at 2:20 PM
RHALL77
  • 3,361 POSTS
do you have any other keys at all. if not try this. let the key off for a few minutes. crank it over real quick and watch the security light blink. this will take between 10-30 min. whenit stops, turn the key off for 10 seconds then try to restart.
Apr 17, 2008 at 2:37 PM
STEPHANIEFORD
She only has the original and a copy--but the problem is that the ignition place in the steering wheel won't even turn in order to try crank the car.
[quote:58f90af2a2="rhall77"]do you have any other keys at all. if not try this. let the key off for a few minutes. crank it over real quick and watch the security light blink. this will take between 10-30 min. whenit stops, turn the key off for 10 seconds then try to restart.[/quote:58f90af2a2]
Apr 17, 2008 at 2:41 PM
RHALL77
  • 3,361 POSTS
if it is stuck there isnt much you can do with out breaking something. sorry. just try to work it out. if not you will have to get it towed
Apr 17, 2008 at 2:44 PM
