1999 Chevy Venture locks
1999 CHEVROLET VENTURE
MAMA2007
Electrical problem
1999 Chevy Venture 6 cyl Front Wheel Drive Automatic
I just got my van out the transmission shop yesterday and when i put it into drive my doors no longer lock automatically and when i use the keypad to lock and unlock the doors the horn no longer beeps and the lights no longer flash what do i need to do?
Feb 19, 2010 at 6:15 AM
DAVE H
  • 13,384 POSTS
AUTOMATIC DOOR LOCK OPERATION MODES
Mode 1
Shift out of Park lock, ignition off unlock, and shift into Park unlock modes are disabled.
Mode 2
Shift out of Park mode enabled. Ignition off unlock and shift into Park unlock modes disabled.
Mode 3
Shift out of Park and ignition off unlock modes are enabled. Shift into Park unlock mode disabled.
Mode 4
Shift out of Park lock and shift into Park unlock modes enabled. Ignition off unlock mode disabled.
CHANGING AUTOMATIC DOOR LOCK OPERATION MODE
Turn off instrument panel dimmer switch. Turn ignition switch to LOCK position.
Remove BCM PRGRM fuse located in instrument panel fuse block. Turn ignition switch to ACC position. BCM will sound chime (2, 3 or 4 chimes) corresponding to BCM type installed on vehicle. BCM has now entered the feature customization mode.
To change automatic door lock operation mode, press and release LOCK on either door lock switch. BCM will sound chime a number of times equivalent to automatic door lock operation modes. See AUTOMATIC DOOR LOCK OPERATION MODES . When Mode 4 is reached, Mode 1 will be repeated. To exit and save current customization mode, turn ignition off. Replace BCM PRGRM fuse.
CHANGING LOCKING CONTROL MODES
Turn off instrument panel dimmer switch. Turn ignition switch to LOCK position. Remove BCM PRGRM fuse.
To change locking control mode, press and release UNLOCK on either door lock switch. BCM will sound chime equivalent to locking control mode. When Mode 4 is reached, Mode 1 will be repeated. To exit and save current customization mode, turn ignition off and reinstall BCM PRGRM fuse. The lock control modes are as follows:
Mode 1
Last door locking and lock-out prevention disabled.
Mode 2
Last door closed locking disabled. Lock-out prevention enabled. BCM will not lock doors when pressing LOCK on either door lock switch and key in ignition cylinder but driver-side door is open.
Mode 3
Last door closed locking enabled. Lock-out prevention disabled. This mode locks all doors 5 seconds after closing all doors when pressing LOCK on either door lock switch with ignition switch in LOCK position.
Mode 4
Last door closed locking enabled, will lock all doors 5 seconds after closing all doors when pressing LOCK on either door lock switch with ignition switch in LOCK position. Lock-out prevention enabled, will not lock doors when pressing LOCK on either door lock switch with key in ignition cylinder but driver-side door is open.
Mar 12, 2010 at 8:31 AM
