1999 Chevy Venture humming sound
1999 CHEVROLET VENTURE
200,000 MILES • 6 CYL • FWD • AUTOMATIC
BILLYBOBKRAZY
every time i drive the van am getting a humming sound coming from the front end it gets worse when i turn corners or louder
Jul 2, 2009 at 11:00 AM
HEYOU100
  • 6 POSTS
Sounds like a wheel bearing. You can determine which side it's coming from. Steering either left or right, the noise or hum should increase or decrease. If the noise gets worse when you turn the vehicle to the right, then the left bearing needs replaing, (steering to the right puts more weight on the left front wheel). If the noise gets worse when you turn the vehicle to the left, then the right bearing needs replaing, (steering to the left puts more weight on the right front wheel).
Apr 22, 2010 at 7:31 PM
