1999 Chevy Venture Diagnostic System Check codes
1999 CHEVROLET VENTURE
930,103 MILES • 6 CYL • 2WD • AUTOMATIC
TROY325
  • 5 POSTS
my bcm has a code 1234 what is this and how can i reset it?
Feb 16, 2008 at 10:57 AM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/forum/automotive_pictures/62217_BCM_Codes_1.jpg
These are the Valid BCM codes, cannot find yours!
Feb 16, 2008 at 11:50 AM
TROY325
  • 5 POSTS
well I'm trying to reprogram the key fob/remote and i remove the bcm fuse and turn the key to ACC it chimes lvl 4 but when i turn the key to off then ACC it chimes---chimes-chimes---chimes-chimes-chimes---chimes-chimes-chimes-chimes---then repeats X3 times whats that then? or am i going at reprograming the fod/remote all wrong?
Feb 16, 2008 at 12:05 PM
MERLIN2021
  • 17,250 POSTS
It may be stuck in a program mode...try putting the fuse in and starting over...
Feb 17, 2008 at 9:15 AM
TROY325
  • 5 POSTS
i found the problem my daughter turned on the back two lights after i turned them off i didn't get that error but i think my receiver is broke, i took my key fob to auto-zone and checked it, its good , so i guess the receiver isn't receiving :(
Feb 18, 2008 at 6:23 PM
MERLIN2021
  • 17,250 POSTS
So both transmitters dont work?
Feb 19, 2008 at 7:13 AM
TROY325
  • 5 POSTS
i only have the one, should get a new remote? i can get new one for about $35, or try replacing the receiver?*i have heard from others that receivers don't go out that often*.
Feb 19, 2008 at 10:13 AM
