1998 Chevy Venture High Idle
1998 CHEVROLET VENTURE
130,000 MILES • V8 • 2WD • AUTOMATIC
BIGEARLY
My van has a high idle after driving it . It happens a lot but not all the time. When it does i can shut it off and restart it and idles fine till the next time, I have no tac but it will travel 30 plus miles an hour with out touching the gas. Replaced the IAC motor and seem to act up more often. Engine light does not come on. I know light works cause it came on for a different problem. Thank you Ted
Sep 23, 2010 at 2:22 PM
WRENCHTECH
  • 20,761 POSTS
You need to check a couple things. First check it thoroughly for any vacuum leaks and repair them. Then clean the throttle body. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle.
Sep 23, 2010 at 2:41 PM
