1998 Chevy Venture change oil pump
1998 CHEVROLET VENTURE
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
BUTCH57
how do I change the oil pump with out pulling the engine.
Mar 30, 2008 at 1:14 PM
RHALL77
  • 3,361 POSTS
You can try to pull the oil pan but i dont think it could be done. You most likely gonna have to pull the engine.
Mar 31, 2008 at 7:54 AM
DENNYP
  • 1,824 POSTS
You will need to remove the engine cradle or raise the engine enough to remove the oil pan. I personally think it's much easier to remove the cradle. The oil pump is on the rear main bearing cap.
Apr 5, 2008 at 7:57 AM
