A/C system
CHEVROLET VAN
COLATECH
I have a 2001 Chevy express with 160,000 miles.
A/C works only for a while when first started. I loose all voltage to the cycling switch. Of course then the compressor will not kick in.Where do the wires go to from the cycling switch? I have swapped the A/C relay.
Aug 10, 2007 at 1:10 PM
CLY
  • 308 POSTS
It looks like the feed for that switch(green wire)comes from the powertrain control module and the black wire splices into the ground curcuit for the compressor. I would have the codes checked and see if maybe the computer is camanding the a/c system off for some reason.Not all codes will turn on the check engine light. You may have a low freon code or something setting...
Cly
Aug 10, 2007 at 4:06 PM
