when i turn on headlights both headlight and console
lights flash off and on
Aug 22, 2009 at 7:42 AM
MERLIN2021
CERTIFIED EXPERT
I would check the headlamp switch and connector, sounds like a loose wire/connection. Check for bent or pushed out pins, if all checks OK, scan for codes with a scanner comparable to a GM TechII scan tool.
Generic scanners wont read BCM...
