just sent a question . 1 more also put driving lights on front bumber. do i need a relay on that?.gone to put a on/off switch inside for that light
Mar 7, 2009 at 1:43 PM
JAMES W.
CERTIFIED EXPERT
As long as you tie into your regular headlight circuit or switch, and you use a heavy enough switch, you won't need a relay. BUT, From where ever you pull your power source, make sure you put in a fuse or you may wind up with a melt down. Hope this helps.
