1995 Chevy Van Rear heater control valve
1995 CHEVROLET VAN
85,800 MILES • V8 • 2WD • AUTOMATIC
JIMMIEZ
  • 31 POSTS
I think this the correct name for this valve.....it's a diaphram valve with a vacuum line control that has in/out 1/2" heater hoses, but it also has a 2 foot long, 1/2" rigid metal tubing attached (at 90 deg.) that connects under the frame to a heater hose going to the rear of the vehicle. Its mounted on the firewall. This valve is leaking. Question, 1. Is the metal tubing permanently connected to the valve? It appears so, but difficult to tell due to poor visibility. 2. How does one remove this valve/assembly?
Sep 6, 2009 at 1:37 AM
MERLIN2021
  • 17,250 POSTS
There are two ways to replace it, one is with recreational package the replacement is 115.00 dollars.
https://www.2carpros.com/forum/automotive_pictures/62217_HeatControl_1.jpg
Or with one that is not recreational. 15-20 dollars.
https://www.2carpros.com/forum/automotive_pictures/62217_heatcontrol2_1.jpg
I would use a hose clamp to clamp the hoses, this saves you from draining and refilling the system. Usually there is a brackett attached to it, remove the hoses, bolt secring the brackett, and remove!
Sep 6, 2009 at 7:52 AM
JIMMIEZ
  • 31 POSTS
Thanks for the quick reply!! Since the two valves you show are so different, I assume they are not interchangeable. My valve looks exactly like the one with the metal tube...the other one has one too many hose connections for the setup I have. If they are interchangeable, which extra hose connection would I block?
Also, is there anything major under the hood I have to remove to get that long tube version out of the engine compartment? Actually, I could cut the old one, but I'd appreciate knowing what to remove to be able to install the new one, if that's the one I must use!!
Sep 6, 2009 at 10:48 AM
MERLIN2021
  • 17,250 POSTS
These are NOT interchangeable! One is recreation package and one isnt. You may need ramps or a lift to get at it...other than that do like I said, clamp the hoses to avoid draining the system...
Sep 6, 2009 at 9:43 PM
JIMMIEZ
  • 31 POSTS
Thanks Merlin 2021...got it out this evening! Had to pull it out through the bottom at the right front wheel well. Thanks for the tip to clamp the hoses...saved a lot of nuisance work. Hope I can get the new one in the same way.
Sep 7, 2009 at 11:12 PM
MERLIN2021
  • 17,250 POSTS
Your welcome, and yes you should be able to get it in the same way! Thanks for the points.
Sep 8, 2009 at 5:52 AM
JOEBULL05
I'm aware this thread is crazy old, but I can't find that heater valve to get a replacement. This mystery leak has led me on a chase for months only to find that the valve I need can't be found online. Please help a brother out!!
May 16, 2024 at 5:35 PM
Is this the same year, make, and model as the original post? If it is, let me know. If it is a different year or model, I will need you to start a new post. We do that because it is more helpful to others.
Here is the link to start a new post:
May 16, 2024 at 7:14 PM
