I think this the correct name for this valve.....it's a diaphram valve with a vacuum line control that has in/out 1/2" heater hoses, but it also has a 2 foot long, 1/2" rigid metal tubing attached (at 90 deg.) that connects under the frame to a heater hose going to the rear of the vehicle. Its mounted on the firewall. This valve is leaking. Question, 1. Is the metal tubing permanently connected to the valve? It appears so, but difficult to tell due to poor visibility. 2. How does one remove this valve/assembly?
Sep 6, 2009 at 1:37 AM
