1995 Chevy Van engine wont stay running
1995 CHEVROLET VAN
219,000 MILES • 6 CYL • 2WD • AUTOMATIC
AJ12560
engine will crank and run for about 10 minutes,will rev and idle good . then it just shuts down like you turned the switch off-will restart but does same thing.replaced fuel pump,filter,relay,coil pack,icm.prior to i pressure washed front interior-ecm is located under drivers seat. may have gotten wet.service engine light not on but jumped obd1 and got code 32.could egr or egr solenoid cause this or am i leaning to ecm.
Sep 29, 2009 at 8:18 PM
If the EGR valve is open it will create massive vacuum leak and engine will idle erractically or not at all-try cleaning it out and see what happens. Also check the fuel pressure.
Sep 30, 2009 at 7:33 AM
