1994 Chevy Van CHECK ENGINE MEMAGE LIGHT
1994 CHEVROLET VAN
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
GREG MCKINNEY
THE TRANSMISSION WITH NOT CHANGE GEAR FROM TAKE OFF TO THE NEXT GEAR[ CAN ONLY DRIVE AROUND 45 MILES PER HOUR. CHECK ENGINE LIGHT COMES ON AND THE AIR BAG LIGHT
May 17, 2008 at 9:44 AM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/forum/automotive_pictures/62217_95_OlderGM_21.jpg
Cross these two terminals as shown, then turn the key on. Count the flashes, a 22 will flash as 2 flashes then a short pause, then 2 flashes, if more than one code is stored, the pause will be longer. The codes will display three times and end with 12. Write them down and post here. This connector is right under the middle of the dash...
May 17, 2008 at 10:01 AM
