1994 Chevy Van brake lights
1994 CHEVROLET VAN
130,000 MILES • V8 • 2WD • AUTOMATIC
HUNTING63
The brake lights on my van quit working. I have replaced the fuse, bulbs and brake pedal switch. Where do I go from there? Is there a relay I need to look for?
Mar 6, 2009 at 5:20 AM
JDL
  • 16,098 POSTS
Hello, I saw what you replaced, did you do any testing?
Even if the fuse is good, the fuse circuit has to be hot.
Did you check for voltage going to and from the brake switch? What model is the van? The lower brake lites are usually wired through the turn switch. I can't tell you the switch is faulty without testing.
Mar 6, 2009 at 8:18 AM
