1993 Chevy Van rearend
1993 CHEVROLET VAN
160,000 MILES • V8 • 2WD • AUTOMATIC
PZC63W
howl in rearend gets louder as i go faster
May 22, 2010 at 12:15 AM
CONSAKA
  • 31 POSTS
[quote:939d9d9047="pzc63w"]Drive Train Axles Bearings problem
1993 Chevy Van V8 Two Wheel Drive Automatic 160000 miles
howl in rearend gets louder as i go faster[/quote:939d9d9047]
Yes when the bearings fail or the gear teeth get chipped or worn it will make a louder sound as you go faster. So will bad rear axle bearings. Id check those first.
jack up the back of the vehicle, remove the wheels, remove the brake drums, check how much play is in the axle while watching the oil seal. if it is leaking oil then you will likely need a new seal at minimum and possibly new axle shafts as well.
May 25, 2010 at 10:11 AM
