My 92 chevy G-10 Shifter is "loose" that is there is no positive detents as you move the lever thru its range. The trans operates as it should down and up shifts you just have to move the lever around to find the correct gear. The shift cable and lever itself are secure, it appears the problem is in the ball and sliding detents that are around the column. Hope this is a common problem. Thanks Peter
Jan 22, 2008 at 1:00 PM
