1988 Chevy Van van wont run
1988 CHEVROLET VAN
16,500 MILES • V8 • 2WD • AUTOMATIC
TROUSER
have 12 volts going to the coil no spark at distributer. installed new coil had ignition mod checked. no power to tbi injectors. used test light to check this problem. only 6 lbs of pressure from electric fuel pump. Installed new fuel filter still no gas to throttle body. dont know why i lost power to ignition and to injectors at same time.
Sep 24, 2009 at 10:59 AM
Check the ECM fuse it powers the injectors BTW your fuel pressure is low-should be 9-13psi
Sep 24, 2009 at 11:55 AM
