What is the procedure to replace the starter on this vehicle? Thanks!
Mar 1, 2008 at 11:43 AM
MERLIN2021
CERTIFIED EXPERT
Remove the negative(-) battery cable, then remove the wires at the starter, remove the two bolts holding the starter, be careful the starter is HEAVY! use caution removing the last bolt. Install is the reverse of the proceedure!
