wobble
CHEVROLET TRUCK
TRICKEY53
I have a 1997 chevy 1 ton dually 2 wheel drive. 150,000 miles. I have developed a wobble at about 60 mph. It is in the rear of the truck. I put on new rear tires and it seemed to get worse. The wobble is a back and forth motion and you can see the bed moving in the mirror. It is not a up and down vibration like an out of balance problem. I have checked for tightness on everything from Inner hub nuts to shocks. to lug nuts and can't find any problems.
Jul 15, 2007 at 7:07 PM
[quote:f3415b0922="velozn"]2000 ford taurus 120000 miles 6 cilinders
I cant remove the rear brakes drums, please tell me how[/quote:f3415b0922]
There's an inspection hole behind the backing plate-turn the starwheel on the adjuster to retract the brake,then hit it with a rubber mallet to loosen the drum away from the shoes.
Jul 16, 2007 at 3:16 PM
