truck shuts off then turns back on while driving
CHEVROLET TRUCK
CRAWN10
Chevrolet Silverado, 2001,94000 miles, engine 8.1. My question is, my truck will quit running while driving down the road,if you keep costing it will turn back on. I have asked this question before and gave a small donation and have gotten no reply back.please help. :!:
Jul 20, 2007 at 7:50 PM
This sounds very much like an engine controller issue. Basically if the ignition shuts off or stops firing the spark plugs then the engine will stop running. However, if you are still in gear the drive-train can remain connected to the engine and that means the pistons will continue turning. If that is the case, all the PCM as to do is start firing the plugs again and the engine will start running again.
So if I understand the issue properly, if the engine shuts off driving down the road or sitting at a stop light and restarts "by itself" then that is an ignition issue. So that means we need to look what controls the ignition which is the ignition switch and then the PCM.
If the dash does not "restart" like when you are first starting the vehicle, I would go ahead and replace the PCM.
Mar 26, 2020 at 3:46 PM
