secondaries wont open
CHEVROLET TRUCK
DELLGPX
  • 9 POSTS
I have a 1983 Chevy Silverado with a 350/290 HP crate engine along with 700R4 Tranny and a 600cfm Holley Carb that wont open the secondaries wile in the D position but will in the 3rd gear position, even with a load on the engine. I have no clue why because I got better secondary response out of my Rochester, I could stomp the gas pedal to the floor and it would immediately shift to second and pass everyone, now I have to shift to third with the column shifter just because things aren't working properly. What do I do about this?
Mar 22, 2007 at 12:12 AM
DELLGPX
  • 9 POSTS
I am just letting you know that you were right about one thing, the tv cable had slack, i opened the lock with a screw driver, pressed the cable forward and let the lock go then i pushed the throttle all the way open to secure that, now it shifts great and opens the secondaries when I either put it to the floor in overdrive or in third, but I also moved the screw on the carb. cam and that gave it the fuel it needed so it wouldn't stall. Thank you for your time and information, it was helpful.
Mar 24, 2007 at 11:38 AM
