Power Brakes and Power Steering dead
CHEVROLET TRUCK
T BONE
'93 Chevy chassis in Dutchmen motor home with 454 chev engine lost almost all power steering and power brakes--only very limited assist in each, and the power steering pump groans when you press brake pedal or turn steering wheel. Fluid level is good and belts are tight. Are both running hydraulically off the pump? I see no vacumn booster for the brakes, and the pump does groan when you press brakes and don't touch steering at all. Any ideas what it may be? I cannot drive it--it is 33 ft long and heavy so hard to manuver without the pwr brakes/steering.
Aug 3, 2007 at 8:33 PM
BOOTDOG
  • 665 POSTS
the pump is going bad. replace the pump and it should be fine.
Aug 4, 2007 at 8:17 AM
