please help me with this problem
CHEVROLET TRUCK
NY_WILLY
  • 5 POSTS
i have a 89 ford 1 ton with a 351 windsor, the truck starts for about 10 min. then dies, and it wont start again, for another 3 to 4 hrs.and does the same thing again. ive change every thing possible and no one here where i live has been able to solve the problem, ive change pick up coil, coil, madular,relay switch , wire , plugs, cap, rotor and still the same problem, can anyone heilp me, i realy would appriciate it thank you!
Oct 26, 2007 at 10:32 PM
Try checking the ISC air bypass solenoid. Don' work when it dies out immediately look for spark and fuel one of this is gonna be missing. Also might want to check the fuel pressure could be the fuel pump getting sloppy. Also test out the ECU power relay
https://www.2carpros.com/forum/automotive_pictures/12900_idle_bypass_1.jpg
www. .com
Oct 27, 2007 at 6:33 AM
Inbox :: Message
To: rasmataz
Posted: Sat Oct 27, 2007 9:02 pm
Subject: request
I want to thank you for your reponds to my truck problem, i sure hope that by checkiing these things it will work, thanks again! by the way where can i get the picture which you showed me?
@ www.ondemand5.com click on Mitchell1 top center of page and go from there should be on the left column for manuals next page.
Try to duplicate the problem this is the best time to catch the culprit on the act. When it stalls look for spark and fuel immediately don't give it a chance to rest look for it one of this is gonna be missing-
Oct 27, 2007 at 10:44 PM
NY_WILLY
  • 5 POSTS
its not the fuel, its the spark, i get no spark on the coil or the plugs what can i do? i dont know what else to do, ive tryed every thing i know, which isnt much . thank you!
Oct 28, 2007 at 8:46 PM
Do you have power at the coil positive terminal when key is in On position. if so how did you check the ignition control module? and where is it located? Also how did you check the pick-up coil in the distributor.
Double check all your connections to the distributor and module. The get back to me.
You changing all that stuffs that tells me you have a distributor.
This is how it goes on this type of ignition Dura Spark 1/2 The pick-up tells the computer the position of the pistons and engine speed when the computer gets it-it turns around and tell the ICM to fire that cylinder thru the coil.
Oct 28, 2007 at 11:19 PM
Inbox :: Message
To: rasmataz
Posted: Tue Nov 27, 2007 11:36 pm
Subject: 1989 ford 351
i wanted to thank you for your help in solving my problrm with my truck, you adviced me of things i had no knowledge of,i also want to tell you that my truck has two gas pumps one inside the tank and one on the outside thats the one that was not working , plus the engine light on was the trotle body sensor...... thanks again........ willy
You're very welcome and Happy Holidays
Nov 28, 2007 at 12:11 AM
