Crank sensor 98 chev 4.3
1998 CHEVROLET TRUCK
PULVERISOR
I've got a 98 chev pickup 2wd 4.3.
It keeps giving me a code 338.
Its now at the point where it almost impossible to drive which is why I'm getting frustrated cause I have checked everything except the wiring, I'm getting the vehicle back tomorrow so I will check for shorts in and connection problems in the circuit to the module and the pcm.
I've tried a new crank sensor, no go.
I normally have distributor problems so I changed that. no go. normally I get a crankshaft camshaft correlation code when its a distributor problem.
I thought possible timing chain slack cause my cam retard is bouncing around -10 to -11. which I know isnt right. should be 0 to -4. Any ideas would be great thank you.
Aug 8, 2007 at 6:46 PM
[quote:214721c13f="pulverisor"]I've got a 98 chev pickup 2wd 4.3.
I thought possible timing chain slack cause my cam retard is bouncing around -10 to -11. which I know isnt right. should be 0 to -4. Any ideas would be great thank you.[/quote:214721c13f]
P0338....Crankshaft Position Sensor A Circuit High Input is it getting the voltage reference from PCM?
Aug 11, 2007 at 5:32 PM
[quote:bf48ce4970="pulverisor"]I've got a 98 chev pickup 2wd 4.3.
I thought possible timing chain slack cause my cam retard is bouncing around -10 to -11. which I know isnt right. should be 0 to -4. Any ideas would be great thank you.[/quote:bf48ce4970]
The CPS function the same way as the pick-up and trigger wheel in an electronic distributor.
Its purpose is to tell the PCM the position of the crankshaft and the no.1 cylinder to include the engine rpm.
Note: some engines uses a seperate Cam sensor that the PCM uses to determine the correct firing order.
In the event the CPS fails completely the engine will not start and its normally caused by a sensor wiring harness problem
Aug 11, 2007 at 5:49 PM
