Climate Control
CHEVROLET TRUCK
DRLIVING
I have a 1992 Chev K 1500, 350 ci, 65k miles. When I turn on the heater, the vent arrows flash for about 1 minute then stop. I can't move the air flow from floor to defrost, but air blows out the vents. It doesn't matter if its heat or a/c. Is the flashing a electrical code or is it a vacuum line under the dash that is leaking or broken?
May 14, 2007 at 5:46 PM
2CARPRO JACK
  • 11,533 POSTS
No vacuum in there. Disconnct the plug to the blend actuator, check for voltage, should be 6-7.5 , if lower replace controller, if in range replace the actuator
May 15, 2007 at 11:04 AM
