change pitman arm
CHEVROLET TRUCK
NPETE55
I have a 1998 3/4 ton silverado 4x4 pickup. 200,000 miles, 2500series, 5.7 engine... I need instructions to remove and replace the pitman arm.
Nov 10, 2007 at 12:28 PM
MERLIN2021
  • 17,250 POSTS
First, you will need a pitman arm puller, the right sized socket, and possibly a tie rod fork. Seperate the ball-joint end of the arm, undo the large nut at the bottom os the sector shaft, install the puller and torque it down and tap the pitman arm with a hammer as you tighten the tool...will eventaully pop off!
Nov 10, 2007 at 12:47 PM
