i got this truck for 100 bucks, great condition, the guy said the motor was locked up, i took it home, it wasnt, a batt. cable was loose, it ran rough, the heads were blown, i fixed that, it ran fine for 2 weeks, then the check engine light would come on, it idled rough, ran rich, stalled out, wouldnt start, i ran dionogstics on it, a map sensor code, iac code and a tps code, i replaced those and the o2 sensor and the plugs, the touble codes are clear , but it still runs poorly, i ran a compression check, all 6 cylinders are within specs, there is no water in the oil or vice versa, can anyone know how these vortecs, work??, thanks :x
Jan 3, 2006 at 12:18 PM
