2003 Chevy Truck key will not turn and shift is locked
2003 CHEVROLET TRUCK
86,000 MILES • V8 • 4WD • AUTOMATIC
MRLARRIVEE
The key won't turn in the ignition and the shifter on the columum is lock into place
Oct 18, 2008 at 10:17 PM
IMPALASS
  • 3,112 POSTS
Hello, have you tried gentle turning the steering wheel,from left to right to the stops and then try turn the key?
Oct 19, 2008 at 12:44 AM
MRLARRIVEE
Reply to your question the Steering wheel is not locked an you can turn completely to the right or left. Only the Shift will not release so you can not put it a different gear it lock in park and the key will not turn.
When you put the key in all the way the little bell sound
ding like when it warns you that the you have left the keys in the ignition
I have a remote starter and can start the car but the motor will shut down the motor when you put your foot on the brake just like it suppose to.
Oct 19, 2008 at 1:43 PM
IMPALASS
  • 3,112 POSTS
There are numerous models of Chevy trucks. Please be specific on the model of your truck and the engine so that we can look at your specific vehicle. Thanks
Oct 19, 2008 at 7:24 PM
MRLARRIVEE
I ave a 2003 1500 HD 4 wheel drive I don't know the size of the engine but it an 8 cylinder
Oct 19, 2008 at 7:40 PM
IMPALASS
  • 3,112 POSTS
Hello I have attached some troubleshooting info for you. If the key is not bent as it says and I would check that really well, then my guess is the ignition lock cylinder control actuator. I believe that is why it won't shift. I f the steering wheel is still locked it shouldn't shift. Hope this helps.
https://www.2carpros.com/forum/automotive_pictures/248015_1_5.jpg
https://www.2carpros.com/forum/automotive_pictures/248015_2_3.jpg
https://www.2carpros.com/forum/automotive_pictures/248015_3_1.jpg
Oct 19, 2008 at 9:55 PM
