The gauge cluster has issues. None of the gauges work
2003 CHEVROLET TRUCK
SR71JETMECH
The gauge cluster has issues. none of the gauges work, the odometer is out and the information center is out. I read through some forums and everyone is talking about the stepper motors. There has to be something else as every now and then it will come to life and everything will work for about a mile and then quit. Also when this happens I loose the speedo backlight and another gauge light. All "idiot or other indicator lights still illuminate with key on engine off. I'm thinking a loose ground?? Just wondering if anyone has had a problem like this. Also now the warning chime is on all the time but with no display??? No CEL or any warning light, just the chime.
Thanks in advance, SCOTT
Dec 10, 2009 at 4:58 PM
BRIAN 1
  • 1,030 POSTS
replace the IPC,very common problem.its not the stepper motor,I've never changed one,just replaced the IPC's in these vehicles.this has been an ongoing problem with these vehicles since 03.there is a special policy covering these for 7years 70,000 miles.might want to call the dealer,it might be out by mileage but might want to ask. This video will show you how to fix it.
https://youtu.be/_HEC44xENxw
Dec 10, 2009 at 8:00 PM
SR71JETMECH
thanks for the video, that did it thank you all good now.
Dec 11, 2009 at 11:27 AM
