You can try a "Passlock Relearn" and see if it will take.If this doesnt work youmay need to have the PCM/VCM sscanned to see where the communucation is being lost in the security system
GM PASS LOCK RELEARN- Ignition to "run" position, try to start and let key return to "run" position
Approx ten minutes security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of 3 relearns.
Turn key off, then start it
Mar 16, 2010 at 8:21 AM
