2000 Chevy Truck Fuel gage
2000 CHEVROLET TRUCK
98,700 MILES • 4 CYL • 2WD • MANUAL
SLOBODAN ILIBASIC
my fuel gage on cluster jumps from E to F all the time ,is this electrical or some other problem?
Thanks
Apr 12, 2008 at 7:58 AM
ROWTIEAR
  • 91 POSTS
This is a common problem with gm fuel pumps.
The sending unit for the fuel gage is integrated into the fuel pump.
Recently the aftermarket has come out with a replacement sending unit that can be changed on the existing fuel pump, however these fuel pumps are prone to failure at around 60-80000 miles.
If the fuel pump is original then you are already living on borrowed time and my recomendation would be to just change the whole fuel pump as a unit , this should take care of your problem and perhaps forestall another one.
Hope this helps.
Apr 12, 2008 at 10:21 AM
