1999 Lumina, wiper issue
1999 CHEVROLET TRUCK
GOPHER4
  • 6 POSTS
I have a 1999 Chevy Lumina, 3.1 with 140,000 that has an issue with the wipers. When I want to use the washer fluid, everything works except there is not fluid pumping from the resivor. You can hear the pump motor running, but there is nothing that comes out.
Could there be a clog in my wiper line or just a faulty fluid pump? Or is there a way to check rather than replacing the pump only to find the problem still there. Thanks!
May 12, 2007 at 6:32 PM
SERVICE WRITER
  • 9,123 POSTS
Hook up a separate line, or just disconnect the line and then try the pump. IF it comes out, you have a restriction
May 12, 2007 at 6:36 PM
