1999 Chevy Truck No Voltage at Relay...
1999 CHEVROLET TRUCK
200,000 MILES • V8 • 2WD • AUTOMATIC
MIKE HOUSTON
Starter got stuck engaged for about 30 seconds on my 99 Chevy 3500...blew 40 amp Ignition Fuse. I changed the fuse and got the truck home...attempted to start truck the next day and have no power at the dash when the key is on...(12.8 V.D.C. @ battery and cig. lighter,lights etc)...I checked the Ignition Relay and found that I have no Voltage at the Relay as the key is turned or w/ ACC on....should I have power at the relay base? Is my Ignition Switch faulty? The AC Relay is located next to the Ignition Relay and has voltage ...should I have voltage at the Ignition Relay??? The Wiring Diagram shows that the Relay is powered from the Neutral Switch...but I am unsure if I should have power at the relay before the key is turned....HELP,PLEASE 909-273-9737 tonight
Aug 1, 2010 at 10:24 PM
Hi Mike Houston, Welcome to 2carpros and TY for the donation If the 40amp fuse is okay and there's no power at all on the starter relay socket on the red wire its open from the fuse to the starter relay see below
https://www.2carpros.com/forum/automotive_pictures/12900_starter_relay_chevy_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_starter_relay_chevy1_1.jpg
Aug 1, 2010 at 11:15 PM
MIKE HOUSTON
Thats how you guys roll??? You gonna give me a $5 schematic??? You aren't gonna answer my questions??? This is bullshit...I thought this might be THE forum for help....but you are only interested in taking someones handout w/out actually helping.
Aug 2, 2010 at 11:59 AM
THIS IS MIKE
  • 686 POSTS
We are here to try and help, not to take your money. We do our best to provide unbiased advice and solve difficult problems as quickly as possible. The diagram provided was for your benefit to troubleshoot your ignition circuit. Electrical problems are some of the more difficult ones to diagnose. We answer thousands of questions and patience is required most of the time. We try to go back and forth with our members until we get to the bottom of the problem. We are sorry we could not help you. We have refunded your donation and wish you the best in getting your truck running.
Aug 2, 2010 at 3:46 PM
