1999 Chevy Truck a/c not cooling at idle
1999 CHEVROLET TRUCK
13,000 MILES • V8 • 2WD • AUTOMATIC
DWSMITH43
  • 6 POSTS
i received a little help on this site the other day. engine runs cooler now. problem: my a/c does not cool at low speed or idle. cools great at speeds above 50 mph. replaced engine fan clutch as advised. helped engine but not a/c. cleaned cond. coils, no change. low side feels a little cooler than air temp outside. high side very warm but can hold hand on it forever. with truck in park at raise idle up to 2,000 rpm, no cheange. put water on cond coils and it helped the other day. has not helped but that one time. out of tricks. please help. its hot down here the south coast of texas.
Jun 30, 2008 at 9:49 PM
LEGITIMATE007
  • 5,121 POSTS
how is the air volume inside the vehicle? is it blowing a lot ,alittle, nice and strong?
Jun 30, 2008 at 11:44 PM
DWSMITH43
  • 6 POSTS
it seems to fell pretty normal. i did notice today that it tried to blow a little cool air while sitting in the ferry line with truck still in drive. put in park and straight hot air.
Jul 1, 2008 at 6:37 PM
LEGITIMATE007
  • 5,121 POSTS
really strange, I would have the high and low pressure switch checked, I know vacuum is playing a part in this too, I would , and maybe you can do this your self, is , look under the dash and see if you can locate the mixing doors, put your ebrake on and switch from drive to park and see if those doors move at all, if they do then you have a resistor problem. you'll have to bring it in to the shop and have them trace it.
Jul 1, 2008 at 9:17 PM
