roaring noise while driving
1999 CHEVROLET TRUCK
WHITELIGHTNIN
I have a 1999 Chevy S10 extended cab, 4.3 liter Vortec V6, automatic transmission, 129,000 miles. I have a roaring noise while driving down the road. The tires have been balanced and rotated. My dad said that it may be my one of my universal joints, but I'm not sure. Help! It's driving me crazy.
Apr 10, 2007 at 9:43 PM
MCFERRANCE
  • 100 POSTS
It sounds like you have a bearing hub that is going out here is a video that shows the job being done. I would replace both front hubs.
https://youtu.be/ZgiPRG6jffc
Please run down this guide and report back
Cheers
Apr 11, 2007 at 7:26 PM
WHITELIGHTNIN
The noise does not go away when I turn the steering wheel, it gets louder. There is a real light ticking noise when the steering wheel is being turned while driving. I had a new power steering pump and pressure hose put on in October, and the fluid level and everything is fine.
Apr 12, 2007 at 8:43 AM
MCFERRANCE
  • 100 POSTS
This is assuming the noise is in the front.
Is the noise worse when turning one way more than the other? This could still be a wheel bearing if it is.
Another test.
From a stop turn the steering wheel all the way to the left and the move the truck slowly in a circle. Do this also to the right. Is there a noise then? Is it in the front end?
If yes, it is most likely a CV joint. Look to see if any of the boots are ripped. CV joints usually create more of a clunking noise.
Another idea. Are all of the lights for the 4x4 and the front axle out? I had a lot of front end noise in mine because the front axle wasn't disengaging when I shifted out of 4WD. This ended up being the vacuum switch on the transfer case.
To check if it may be the u-joints or carrier bearing on the driveshaft, jack up the rear and support it with jack stands. Check for play in the u-joints by grasping the drive shaft and moving up and down at each u-joint. Put the truck in neutral and turn the driveshaft 1/4 turn and check each u-joint again. With the truck well supported and in 2WD, start the truck and run it in gear up to 35-40 MPH. Is the noise reproduced now? If so, it is the u-joints and/or carrier bearing.
Apr 13, 2007 at 10:24 AM
WHITELIGHTNIN
It seems to make more noise when I turn the wheel to left. The lights are on 2wd, and when you push it into 4wd the light switches like it should. I had the same problem with the switch a couple of years ago, and its no making that kind of noise again. But like a year ago, I got stuck in a field here on the farm and the truck wouldn't engage in 4wd, the lights on the dash said it was but it wasn't hooking up. Dad pulled me out and as I was backing across the field I felt the 4wd engage.
So I changed the bearing hubs like you said the noises are gone! I love this site.
Apr 13, 2007 at 2:35 PM
