Engine Performance problem
1998 Chevy Truck V8 Two Wheel Drive Automatic 109k miles
I changed the intake gaskets, torqued to specs, and then pressure washed. Now I have a runability problem. Map and tps code thrown. Changed map sensor and reset the computer by disconneting the ground. #1 and 5 cylinders are missing through the throttle stroke. No overdrive. What did I do wrong or where should I look to fix to the problem?
Jun 7, 2009 at 9:20 AM
