1998 Chevy Truck ADJUSTING VAULE LIFTERS
1998 CHEVROLET TRUCK
DTORRES
Engine problem
1998 Chevy Truck V8 Four Wheel Drive Automatic 162OOO miles
I have a 350 vortex engine need to adjust the value
I have a noisey lifter.One vaule was real lose. What is the adjustment.
Jan 12, 2008 at 2:15 PM
PEAR69
  • 1,482 POSTS
Your lifters are hydraulic roller lifters. There is no adjustment as it relates to measurments. The way you adjust these valves is as follows-- Bring no. 1 cylinder up to top dead center on the compession stroke--you can now adjust no. 2 and 5 and 7 intake valves and no. 3 and 4 and 8 exhaust valves. Loosen these rocker arms completely for about 5 minutes. This releases the hydraulic plunger inside of the lifter. Now tighten the rocker arm while spinning the push rod. When the push rod stops spinning stop. Now tighten the nut on the rocker arm 3/4 of a turn or 270 degrees. That's it! Now rotate the engine one complete turn ( 360 degrees) You can now adjust no. 3 and 4 and 6 and 8 intake valves and no. 2 and 5 and 6 and 7 exhaust valves..
BTW a noisy lifter on these motors should always be replaced....
Jan 14, 2008 at 10:18 PM
