1998 Blazer Dim Headlight
1998 CHEVROLET TRUCK
KCMANGOLD
1998 Chevy Blazer LT 4.3v6 4x4 140,000mi. I have dim lights on the right (pass) side of the vehicle. I have checked bulbs and replaced sockets thinking maybe a grounding issue but problem still exists. Is there something else to look for? DRL module, relays, or switch or something?
Jan 23, 2007 at 10:00 AM
MATHIASO
  • 1,209 POSTS
there may be contact corosion in head lamp relay,
you have checked the ground allready,what about the fuse, head lamp connector, in-line connector
Jan 23, 2007 at 11:43 AM
2CARPRO JACK
  • 11,533 POSTS
Fuse 19 is left headlight power and 20 is right power. Be sure you have 12 volts through both fuses
Jan 23, 2007 at 11:53 AM
KCMANGOLD
THANK YOU!! The problem was a corroded fuse for the right side headlamp. THANK YOU AGAIN!!
Jan 23, 2007 at 1:13 PM
2CARPRO JACK
  • 11,533 POSTS
Happy to have saved you a trip to the shop
Jan 23, 2007 at 4:50 PM
