1997 lumina lost mpg
1997 CHEVROLET TRUCK
TIGERANN
My 1997 chevy lumina has lost 6 mpg putting me around 13 mpg city. I was wondering what would be causing this or if there are any tips on how to get better gas millage. :cry:
Aug 7, 2006 at 8:07 AM
MIKEYBDMAN
  • 623 POSTS
[quote:463a7de3b8="tigerann"]My 1997 chevy lumina has lost 6 mpg putting me around 13 mpg city. I was wondering what would be causing this or if there are any tips on how to get better gas millage. :cry:[/quote:463a7de3b8]
I would first check to see if there are any stored engine codes. Then you will need to check the fuel system for problems. A fuel pressure check, along with an injectoer coil test should be done. Also check the fuel pressure regulator vacuum hose for fuel. If it has fuel, replace the pressure regulator. Of course if the pressure is not being regulated replace the regulator. If an injector fails the coil test, replace the bad injectors.
Aug 11, 2006 at 8:31 PM
