1997 Chevy Truck engine surging
1997 CHEVROLET TRUCK
220,000 MILES • V8 • 2WD • MANUAL
LUKESKY
I have a 3/4 ton 6.5 turbo diesel. I just replaced and moved the PMD as well as replaced the lift pump and all of the filters. The engine will start just fine, but surges continuously even when the accelerator is pushed. I tried bleeding the fuel system but got no relief. Any ideas?
Jul 23, 2009 at 8:15 PM
DR LOOT
  • 2,311 POSTS
you failed to mention it hasn't electronic fuel injection pump let me know what you so I can assist you
Jul 25, 2009 at 1:58 PM
LUKESKY
Yes sir, it has an electronic fuel injection pump, of which I have replaced the PMD and relocated the PMD to the top of the wheel well just above power brakes.
Jul 27, 2009 at 2:28 PM
DR LOOT
  • 2,311 POSTS
I'm going to have to apologize but I'm a little bit confused the PMD that you're referring to I'm assuming is the injection pump cam signal sensor is that correct? I need to know that before we can move any further.
Jul 27, 2009 at 6:06 PM
LUKESKY
I do not know exactly what it does, but it is a Stanadyne Pump Mounted Driver. This is the part that everyone talks about it going out due to high heat in its factory location. So I replaced it and bought the relocation/heat sink kit for it.The PMD is part #DIPDT76301 @ dieselcare.net
Jul 28, 2009 at 11:25 AM
DR LOOT
  • 2,311 POSTS
okay I am on the same page with you now, the PMD is an aftermarket injection pump cam signal sensor, need to ask you a few more questions was the trucks surging before you installed this aftermarket PMD? how was the truck running when it had the original injection pump cam signal sensor? or do it just not run anymore so you replace it with the PMD? the reason I'm asking you these questions is you may have a defective PMD, or a wiring harness going to it. Also make sure the wiring harness has not been damaged by heat or that you are running the wiring harness to close to possibly the glow relay or other electrical components that may cause it to malfunction. furthermore get back to me and give me a little more background on when it started and what you did before it started and after.
Jul 28, 2009 at 8:08 PM
