there is no real trick to it, its pretty cut and dry, unbolt the 2 nuts that hold the master cylinder to it and pull it away then go under dash and unhook the booster rod from the brake pedal then remove 4 nuts holding brake booster to firewall then do the reverse to install
Jun 1, 2021 at 10:47 AM
