my 97 cavalier 2.2 liter base model with 170,000 has had a problem with the turnsignals not flashing or even turning on and the hazard lights dont even come on either... on top of all that the brake lights wont come on no more when pressed down. The headlights stilll work and parking lamps when headlights are on but the outer lights dont come on... i replaced the turn signal switch that didnt do nothing, and i had replace to turn signal/hazard flasher but that didnt work either... but i didnt change both at the same time, could it be that? i also have had problems with heat going cold when you go over 50, but the heat is hot until 50. and sometimes the gauge reads and jumps. ive changed (thermostat+thermostat sensor+ flushed/changed all hoses). Some times when getting out of vehicle after driving i recieve and intense elec/stat shock from the door, maybe thats part of the prob.PLEASE HELP!!! its almost like a possesed car....
Mar 11, 2007 at 2:02 PM
