1996 Chevy Truck wont start- need to check fuel pressure
1996 CHEVROLET TRUCK
140,123 MILES • V8 • 4WD • AUTOMATIC
BRIANB85
I have a 1996 chevy that has had the fuel pump replaced 2 weeks ago, truck started to cut out when accelerating up hill, now it wont start- can hear pump start when ignition is on, I need to know where to check the fuel pressure??
Sep 16, 2009 at 11:01 AM
Do below and comeback with some results
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Sep 16, 2009 at 11:20 AM
