1996 Chevy Truck Low fuel pressure
1996 CHEVROLET TRUCK
GGALLOWS
Engine Performance problem
1996 Chevy Truck 6 cyl Two Wheel Drive Automatic
This is a chevy w/t with the 4.3 cpi engine. Cranks but won't run. Fuel pressure showed 15 psi. Replaced fuel pump and filter. New pump shows the same 15 psi. Returned pump and installed a second new pump thinking the first was a dud. Second new pump shows same 15 psi. Pump amp draw is around 4 amps. Is that low? I've checked and cleaned the pump ground. The pump harness looked ok. I'm stumped on what to check next. Surely I haven't got two bad pumps, Any help appreciated. Thanks
Jun 8, 2010 at 8:39 PM
Hi ggallows, Welcome to 2carpros and TY for the donation.
You fuel pressure is suppose to be 60-66psi for a CPI spider unit-you're leaking pressure-remove the upper plenum and look at the pax side if there's a wash-up the injector is leaking if not the nut kit
Jun 8, 2010 at 8:48 PM
GGALLOWS
Thanks for the reply. Turns out the parts place gave me a pump for a TBI motor, so it was only putting out 15 psi. Got the correct pump and truck is fixed.
Jun 14, 2010 at 10:16 AM
Next time you go buy parts get in here and we'll verify the parts for you.
TBI pump produces only 9-13 psi will never work on t
the CPI system its way too low of a pressure
Jun 14, 2010 at 3:40 PM
