1996 chevy blazer 4.3L engine overheating
1996 CHEVROLET TRUCK
MIDTOWNBOARDER
i have a 96 blazer with appx. 155,000 miles on it. the engine recently started overheating really bad, i couldn't drive it for more than 10 minutes before it would actually shut off because it was too hot. i took out the thermostat and tried running it then and it overheated still although not quite as fast. i checked the oil and it was a milky brown color and was way too full. however it is not blowing any smoke out of the tailpipes. when i take off the radiator cap after running it and letting it cool down, the inside of the radiator looks relatively dry. i just had the water pump replaced a few months ago and there is no coolant leaking from anywhere under the vehicle. i am afraid it could be the head gasket or a cracked block but i can't even drive it far enough to get it to the mechanic much less have the money to fix something like that right now. so any help would be greatly appreciated because if i can fix it myself i will but i don't really know what to look at at this point. thanks.
Apr 19, 2007 at 6:38 PM
Am afraid you have a blown gasket-remove all the spark plugs and crank engine over-coolant coming out from the plug port?
H/Gasket,Head and Block!!!!!!!!!!!
Apr 19, 2007 at 7:11 PM
MIDTOWNBOARDER
ok i will try that and see if anything comes out. thanks.
Apr 20, 2007 at 10:14 PM
[quote:66bd4aafee="midtownboarder"]ok i will try that and see if anything comes out. thanks.[/quote:66bd4aafee]
Ok try this drain the some of it out till you hit full mark-now fill radiator to the top. start the engine for 3mins-shut down wait 10mins-now check the level on the stick if it rises-Think! gasket before head and block
Apr 21, 2007 at 12:08 AM
