OK bare with me my truck when i am in a parking lot or coming to a stop will stumble like its going to stall but never does. Ive tried everything i need your help!! first of all no check engine light. ive replaced EGR valve and solenoid, MAP sensor, temperature sensor, fuel filter, injectors, pressure regulater, purge valve, vacuum lines, ignition module, plugs, wires, cap and rotor, new intake manifold gaskets, resurfaced heads and did a valve grind, new CAT convertor, new rockers, compression 125 to 130 all around, new fuel inlet and outlet gaskets and o rings, new TBI gasket, new TPS sensor. Im telling you guys ive tried everything!! I nee dyour help
Apr 17, 2009 at 3:26 AM
