1994 Chevy Truck spark plug blew out porcelain while runnin
1994 CHEVROLET TRUCK
MIKEPAUL
1994 Chevy Truck 6 cyl Four Wheel Drive Manual
spark plug blew out porcelain while running
what would cause this ?
Oct 10, 2008 at 5:45 PM
BLACKOP555
  • 10,386 POSTS
did the plug blow out of the hole/
check to see if the bridge of the spark plug is bent or the plug is damaged, such as being struck by a piston.
if no damage is noted chances are the porcelain was poor, dropped and then later it cracked due to normal operating conditions.
Oct 10, 2008 at 7:28 PM
SWILLIAMS
  • 597 POSTS
To add a few others I have seen a few plugs with very poor crimps to retain the porcelain and even a couple that were not crimped at all!
Oct 13, 2008 at 5:50 PM
BLACKOP555
  • 10,386 POSTS
very possible as swilliams says.
basically just check to see if the porcelain is still in the plugs, if theres no porcelain at all probably a poor crimp.
Oct 13, 2008 at 6:07 PM
