1994 Chevy Truck sensors
1994 CHEVROLET TRUCK
120,000 MILES • V8 • 4WD • AUTOMATIC
CDOWD
  • 25 POSTS
my truck is running real bad i put new plugs wires and it still is running real bad now i no i dont have any oxagen sensors but it has never ran this bad before so what should i check and will it hurt it if it dont have a oxagen filter now i have it straight piped with no mufflers or catalytic converters
Apr 9, 2009 at 9:26 AM
Check the fuel pressure and comeback with it we start here.
Apr 9, 2009 at 9:31 AM
CDOWD
  • 25 POSTS
its good so what now
Apr 9, 2009 at 12:12 PM
Scan the computer for code/s and then comeback.
BTW what was the fuel pressure reading?
Apr 9, 2009 at 5:46 PM
CDOWD
  • 25 POSTS
60 psi
Apr 9, 2009 at 8:45 PM
CDOWD
  • 25 POSTS
ok do i have to have a oxagen sensor
Apr 9, 2009 at 8:47 PM
Yes sir-you need the oxygen sensor its job is to control fuel demand during closed loop operation.
Apr 9, 2009 at 9:34 PM
CDOWD
  • 25 POSTS
thanks so i need to hook one up but all i got is straight pipes no mufflers or cats so what do i do drill a hole and hook one up? would this make my truck run real bad by not haveing one? thanks for your help
Apr 9, 2009 at 10:11 PM
my truck is running real bad-what do you meant by this-rough idle or what-
Apr 9, 2009 at 11:45 PM
DCS1998
  • 41 POSTS
rasmataz:
This cat has been starting new threads asking the same old question about his 1994 truck. He dont seem to listen to what people tell him to check!
I have read ALOT of your replys to people, and have found you to be very good at being able to troubleshoot via the internet.
There is just something about this guy that makes me wanna sit down, smoke a cigarette, drink a beer, watch a chick flick then blow my brains out with a .40 caliber!
*btw cdowd....its OXYGEN, but I will ALLOW you to call it O2
Apr 10, 2009 at 12:12 AM
DCS1998 I appreciate your confidence in me. If people will listen to us they might end up learning something instead at times they try to educate us with something we've arleady learned thru experiences and certifying the ASE. In this particular case anything can cause a bad running engine-such as compression/fuel/ ignition problems etc
Apr 10, 2009 at 1:05 AM
CDOWD
  • 25 POSTS
no it runs good at idel. it just spit and spuders real bad when you drive it.
Apr 10, 2009 at 6:46 AM
Check the throttle position/manifold absolute pressure and knock sensors-
Apr 10, 2009 at 7:25 AM
CDOWD
  • 25 POSTS
hey thanks so much its the oxgen sensor i did a test and it gave me a code the code was 13 which in the maual code 13 says oxagen sensor but i have on last ? ok i can not find were to hook the oxagen sensor up at because some one took it out so ther for i cant find the wire to plug the o2 sensor in at
Apr 11, 2009 at 8:18 AM
Heres the wires that goes to the O2 sensor-see below
https://www.2carpros.com/forum/automotive_pictures/12900_O2_wire_colors_1.jpg
Apr 11, 2009 at 9:25 AM
CDOWD
  • 25 POSTS
ok but my? is what if i dont have them wires. becase someone took them off and i dont have cats the y pipe has been cut off .
Apr 11, 2009 at 10:28 AM
You need to do something about it-I've given all I got-you need to get a repair/service manual and track the wires.
Apr 11, 2009 at 5:20 PM
