1994 Chevy Truck catalytic convertor
1994 CHEVROLET TRUCK
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
ELBIGAL
engines chokes up and catalytic convertor gets red hot. Prior to this a starter was installed, positive cable for battery was replaced, and gas filter was replaced after trouble started
Jan 12, 2010 at 12:14 PM
TOOOMANYTOYS
  • 513 POSTS
If the cat is glowing red chances are there is a restriction in the exhaust system. Most of the time it is the catalytic convertor that needs to be replaced. A way of testing this would be to remove the exhaust before the catalytic convertor. Note it will be loud and is not recommened to drive around. If symtoms go away work your way back from there
Jan 12, 2010 at 12:21 PM
