I'll get right to it. The engine runs perfect and the tranny shifts smooth in D or OD, burt while driving at around 80 KM if I give it a little extra gas it starts to shake pretty bad I have to let off the gas a little to stop the shake but then when I get cruising again and give a little gas it starts to shake again. Same when cruising at say 90 or 100 its ok but after a few minutes if I give it a little extra push it starts to shake. I have checked the U-joints and the drive shaft both are tight with no extra play. The RPM's dont bounce when it starts to shake kinda taking a miss out of the equation as the engine doesnt seem to be missing and the shake is constanjt once it starts until I let off the gas.
Apr 18, 2009 at 3:33 PM
